Old 01-27-2011, 07:59 AM   #2
jcb986
jcb986's Avatar
I would recommend changing AOS...it usually is the problem and this part seems to be an issue and fails eventually. As the AOS fails you get oil being sucked into the intake...after sitting overnite you get the blue smoke burn and maybe a rough idle at first then it goes away after you have burned out the oil.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
