Old 01-25-2011, 12:50 PM   #1
RandallNeighbour
Windscreen Repair
The pin on the black part of the frame on my windscreen snapped off this weekend while attempting to install it after I put my aftermarket humps on the car. These use velcro straps that sit between the installed windscreen on the rollbar on either side of the center tab that holds it in place and they've stressed it to the point of breaking.
The pins fit in the grooves on the black plastic receptacle on each side of the roll bar.
Has anyone purchased the black frame for the windscreen by itself, or must I now purchase a used windscreen and discard this one?
I've got a good mind to grind some slots in the bottom of it and permanently mount it to the center of the rollbar with black silicone. This way I could slip in the velcro pieces without removing it and I'd be good to go. The only time I remove it is when I'm driving across country with the top up and I want that tiny bit of storage space behind the roll bars... and I probably won't drive across country again in it since I put in a race suspension.
BTW, I have already superglued it back on, but I know from experience that this won't last long and it will break and fly off when I'm on the freeway with the top down.
Note: Before you post a reply about replacement tabs sold by Porsche, this is NOT the piece to which I am referring. I have an extra pair of those in my toolbox. This is the tip of the black frame that goes around the Lexan plastic.
