Old 01-25-2011, 10:16 AM   #2
Burg Boxster
yep - sounds like a blown fuse... look in the fuse panel for the guide and a few spare fuses to replace blown one w/. Suspect if you tried to put gas in the car right now, you'd also have a problem w/ nozzle shutting off...
Incidentally, you probably have two fuses out (one will be E6 IIRC) but before replacing and blowing new ones, I'd also check your hard wiring set up as I suppose something may have come loose from the OEM carphone/aux power source behind the lower center console...
Good luck
