Old 01-22-2011, 11:30 AM   #3
BYprodriver
BYprodriver's Avatar
If you want to get the max treadlife from your tires buy a tread depth gauge & measure each tread groove often to see if your alignment &/or air pressure needs adjusting. The wider the tire the harder it is to get even wear across the tread surface.
