Old 01-22-2011, 05:31 AM   #10
blackbox
Leaking is a sign of wear. This is not like tire or shock wear. This is the catastrophic kind of wear that you may not have a chance to repair if it completely quits on you.
My car has about 78K miles on it. If you're anywhere close to that and haven't replaced yours, you should definitely inspect it (hopefully around clutch R&R time).
My dealer replaced my RMS this summer. When I asked about the IMS bearing, the mechanic said " if it ain't broke, don't fix it". Of course a few months later, it started leaking. I don't recommend Moffit Porsche in Shreveport, La. They wouldn't install a Sachs clutch kit that I already bought because it didn't come in a Porsche box. We all know the OEM clutch kits are made by Sachs.
That said, I know they wouldn't replace the IMS bearing with a LNE retrofit kit.
Tchaikovsky
2002 S Black, H&R Springs & Spacers, GT3 front sway bar, Secondary Cat Bypass, K&N filter, Desnorkled, Aerokit 2
blackbox is offline   Reply With Quote
