Old 01-21-2011, 08:52 PM   #3
wanna986
Originally Posted by blackbox
I'm also starting an IMS bearing R&R. I was going thru the 2nd gear grind in my transmission for about 6 months, when new years weekend the shaft on the side shift lever broke inside the transmission.
I chose to source a used low-mileage transmission instead of a total rebuild. This will get me rolling faster and I can still rebuild my original transmission later(hopefully with a Quaife ATB diff).
I new that I had an oil leak, but I hoped it was the RMS (even though it was replaced about 2000 miles ago under warranty). No such luck. After pulling the tranny, there it was. IMS Leaking.
I got my kit from LNE today. Hopefully all goes well. I'm also going replace the inner CV joints while I'm at it.
If your IMS seal is leaking, it's just the seal that needs replacing, no?
wanna986 is offline   Reply With Quote
