Originally Posted by blue2000s
It's not good for any battery to drain while unused, not even a yellow top. They're expensive so you'll want to care for it properly anyway. Just hook up your battery tender when the car sits for a while and you should be fine. That's the right solution to your situation.
If you just take the car around the block every couple of weeks in the winter, you're not doing it any favors anyway.
THanks, blue, I think I'll be going for a red top and a negative cable.
regarding the "round the block" thing, I never take the car out for a drive less than 20 miles, I was just making a point of how I couldn't get the car out right now to even take it down the street if I wanted to. I learned from you guys on here that short drives that don't put the car through its paces do more harm than good.
