Old 01-20-2011, 05:18 AM   #1
ppbon
ppbon's Avatar
Originally Posted by clickman
Which xenons did you use. Are they the HIDs you sell?
Have you found a problem with the cutoff not being right and blinding oncoming traffic?
Yes.
No.
The HID upgrade kit you install should be bulb-type specific.
Meaning that you should install an H7 compatible kit.
By doing that your light pattern should be very close to OEM because the Xenon's light source should coincide with the headlight's focal point.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
