Old 01-19-2011, 08:39 AM   #1
yelojkt
Originally Posted by stephen wilson
Well, I was thinking about some winter tires, on a second set of rims, after I couldn't even get out of my driveway with 1" of snow on PSll's. I thought if I'm buying wheels, why not "upgrade"?
If you are thinking of winter tires on wheels than you should go as narrow as you can, unless you are wanting to run your porsche wheels as winter set and purchase a wider set of aftermarket wheels to put wider summer rubber on at a later date.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
