Old 01-18-2011, 07:43 PM   #20
sb01box
I have a question."Is this shift linkage mis-match on 6 speed boxster as well?
If it is more of an issue with 5 speed cars, doesn't a typical shifter rests at the 3-4 gear location when in neutral?" And if so, is it possible that the green clip is designed for the 6 speed transmission application where there are four left/right "gates" versus 5 speed with three - left/right alignment is more critical for the 6 speed.
The shortness in the left cable during installation may be due to the basic design focusing on ensuring that there is sufficient movement to engage reverse to the left of the 1st & 2nd gear position.
Has anyone measured the left cable motion for all three (5 speed) or 4 left/right "gate" position and see if the delta is equal to the first to reverse positions on the 6 speed? I am interest but not enough to fight and wrestle the shift knob off of the shaft.
just a thought
sb01box is offline   Reply With Quote
