I opted for standard 997 shifter 3 years ago and had similar "shortness" of the left cable. I felt that with the transmission in neutral and with the shifter held in it's neutral position by the green clip, that each cable should be attached at this position. any other setting would move the shift lever to the left or the right from "nominal"
3 years of daily use. no problem engaging all 5 plus reverse gears
