Old 01-17-2011, 04:51 PM   #4
Gilles
Originally Posted by insite
gilles -
you are correct, HOWEVER: when you adjuste the corners, you have added pre-load to the sway bars. the adjustable drop links are used to REMOVE the pre-load condition that's caused by corner balancing.
Insite
Ok now it's clear, therefore I should save some and get the adjustable links to compliment the KW-V3's, thank you..!
Gilles is offline   Reply With Quote
