The front trunk / boot compartment light failed in my 2000 boxster and the cause was the trunk light switch. I was able to purchase just the switch mechanisim and install it to the trunk latch piece but I don't know if this is the case for all years of Boxsters. I the early Porsche days the switch was a simple spring loaded post but the new switches are plastic rotary pieces...over engineered a bit. If replacing the bulb dosen't fix the problem then it's the switch and it's located at the front of the car where the trunk latch lives.
