A little corrosion on the discs is normal, if sitting or damp (they are made from steel). A bit of braking removes the surface rust and provides normal grip, assuming your pads and rotors are in good shape. When was the last time you inspected them? How many miles on the the set and how hard do you drive? Perhaps you need to re-bed them to remove pad buildup?
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
