Thread: Failed MOT :-(
Old 01-13-2011, 09:38 AM   #1
Flat_Six
Originally Posted by timothy
The switch is inexpensive to replace; mine had similar symptoms this Fall. It is held in place by two small plastic tabs that twist around a metal bracket. This sounds easy but the tight work space and made it difficult to get enough torque by hand. I found it easier to *gently* hold the switch body with channel locks.
Cheers for the replies,
Ill try and source a replacement brake switch online and then set about trying to get it out without grazed knuckles
Lee
Flat_Six is offline   Reply With Quote
