Old 01-06-2011, 03:20 PM   #2
Fluellen
Doc
I wouldn't be so quick to condemn the dealership. It's quite possible that these two leaks are separate incidents.
If an engine leaks as much as you describe, chances are it's been neglected for a long time (not necessarily by you, I am sure there is a PO somewhere...) and likely has plenty of other things that are on the verge of failing. So this may just be unfortunate coincidence.
Fluellen is offline   Reply With Quote
