I had to take off the roll bar cover you mention to replace a broken clip for the windscreen. The roll bar cover does just pull off but it is hard to do and several of the plastic clips that hold the cover on sacrificed themselves in the process. I could not move my cover around as you describe so that may be where your noise is coming from. I would be prepared to replace the plastic clips that hold the cover to the roll bar if you remove it. The covers may have been removed before and the clips not replaced. That would explain the movement you describe. I bought some nylon removal tools from Amazon and I got the replacement clips form ******************************************** (no affiliation to either).
Good luck, finding the noise
