Thanks for the replies. I was excited to make my first post and afterwards did search and found some of the same problems and some of the possible fixes. Lucky I have this as a second car and fixed a few issues on my list today as well as clean and organized my garage to bring it inside. I will check the fuse first after I get home from work Monday. Also the spirited drive sounds like a fun try at a solution.
I thought the gas gauge may not be working correctly however I did drive some Friday and stopped and put gas in. Added around 6 or seven gallons and fuel gauge did read about 5/8ths most fuel I have got in it. So hopefully gauge is functioning correctly.
Both low beams were burnt out when I picked it up? Ordered 2 online due to local price being so expensive.
