I'm betting the grease inside the nylon bushings that allow side to side movement has dried up and is causing a bind. There is one on each side of the shifter. The bushings aren't replaceable/serviceable. You can either replace the whole shifter assembly or just buy a short shifter that does come with serviceble bushings.
