Old 12-30-2010, 10:09 PM   #2
Steve Tinker
Steve Tinker's Avatar
Yes it can happen - age and temperature tend to crack the insulations in varying degrees and once moisture enteres the equation, voltage mistracking will follow.
You can find that one coil is delivering 80% of the voltage to the plug and losing 20% through the breakdown in insulation but still fire the cylinder OK - the next plug along could be losing 30% of its prescribed voltage giving a CEL and reduced performance (missfire).
If you live in a harsh enviroment the coils have a shorter lifespan than in a warm dry climate.
I guess you should replace all 6 coil packs - you should feel the difference in performance too.....
2001 MV Agusta F4.
