Old 12-27-2010, 09:22 PM   #1
sasha055
Rear wheel bearing replacement question
Hi,
I'm in the process of replacing my rear wheel bearing and I hit a problem:
How do I use ball joint separator?
I got one of these : http://www.amazon.com/Specialty-Products-37990-Joint-Separator/dp/B000SIFO3M/ref=sr_1_3?ie=UTF8&qid=1293516917&sr=8-3
However.. I want to push the controll arm down not to press things.. I tried to look online.. but all I see is a fork.. there is no reference on how to use this type.
Also it seems that my wrenches do not fit into small spaces in there? Do I need special (thin wrenches?)
Same goes for torx + 19mm wrench to loosen ball joint bolt.. there is no way a torx will fit on top of the bolt without cutting the CV boot.
How do you guys do it??
One more thing.. if anyone will be writing a DIY guide.. please take pictures and explain how to do these things.. I read both "bearing 102" and pelican parts guide.. and everyone is concerned about how to use SIR tool.. no onw really explains how to get to that point
Sasha
sasha055 is offline   Reply With Quote
