Old 12-25-2010, 08:51 AM   #1
Soetekouw
Congratulations on your 'new' purchase. And you are correct, this forum does provide a wealth of information and there are a bunch of helpful and knowledgeable members. But..........as JakeD and SeanZ4 have also indicated, it seems that you will have some repairs coming up and will have to set up a budget to maintain that Boxster.
A Porsche is not for the faint of heart, nor for those who don't have a bucket full of money. IMHO, I recommend that you have the vehicle checked out by your Porsche mechanic. Unless the previous owner has already done so, at 80K miles, some areas that you may want to look into, are:
1. Oil/filter change (every 5k miles)
2. Spark plugs and ignition coilsl replacement (at 60K miles).
3. Brake fluid replacement (every 2 years)
4. Transmission fluid replacement (automatic) (at 60K miles)
5. Brake pads
6. IMS/RMS repair
7. Water pump/thermostat replacement (2-4 years is recommended)
8. Battery
9. Belt replacement (at 60K)
10. Air Filter / Cabin Air Filter replacement (every 15K)
11. Wiper blades
12. Your top (since you mentioned it)
13. The dreaded quick wearing out tires (every 15K miles)
* some of the intervals may not be iaw the manual, but this is what I would do.
The above services will run you approximately what you paid for your car.
But, as JakeD mentioned, for as little as you have invested in the car, enjoy it while it drives and runs, and when something major goes wrong, it is basically a throw away.
Soetekouw is offline   Reply With Quote
