Originally Posted by kcpaz
This is common and I have yet to work on a car that wasn't this way. String a ratchet strap across the two suspension members and pull them inboard until it takes the pressure off of the studs. Don't put the weight of the car on the suspension without that aluminum belly pan in place. Also, I assume you have the special tool required to remove the drain plug??? if not, you will find yourself stuck again.
I'll try to hunt down a ratchet strap and give that a shot. Thanks! I have a 6 speed.... I read that it doesn't require a special tool only the 5 speeds do. Hopefully that is right.
