Old 12-24-2010, 09:13 AM   #3
JFP in PA
Not really, the OEM fluid has a darker starting color. Different gear oils are all over the map color-wise; there are even "water white" gear oils. All has to do with the base stock the lube is based on, and what additives are being used. Do not be surprised if you find the RL fluid starts being harder shifting after a few miles..................
