Old 12-24-2010, 06:01 AM   #13
j.fro
Rennzenn
j.fro's Avatar
Just to add to the "noise" confusion, the seam at the front of the hood can cause a whistling noise at highway speeds if it is not adjusted properly. The test is to tape the seam closed and go for a drive...if the noise is gone, you've found your problem. The solution is to adjust the rubber bumpers at the hood's corners so that the hood sits just a hair below the lip of the front bumper cover.
