Old 12-22-2010, 03:09 PM   #19
Jake Raby
Engine Surgeon
Originally Posted by kcpaz
I understand that, and I know the bearing itself is the only reason most people even know that the M96 has an IMS. It just seems to me like if there was a way to eliminate the IMS all together, you would be better off, and in-fact, other manufacturers have been able to. Now if you are saying that there is a possibility that the current design of the 9A1 would have benefited from having an IMS, I can't argue because I can honestly say I have absolutely zero experience with that engine, but based on what Subaru (just an example) has done with their engines, I don't see why Porsche wouldn't have the ability to make it work too.
Some component must reduce camshaft speeds by 50%, no matter what the engine may be.. In my experience you want that 50% reduction to occur as early in the mechanical "chain" as possible to reduce surface speeds of chains and etc.
When I first saw the proposed "new engine" I knew it was going to be hell on timing chains.. From the reports that I hear within some dealer networks I am part of failed timing chains are occurring.
US Patent 8,992,089 &
US Patent 9,416,697
