12-22-2010, 12:31 PM
#18
Originally Posted by harryrcb
THat is a real shame, when I installed it on my 97, I had neither of those problems, if you decide to do it, make sure the engine is cold, sitting overnight, the bolts should come right out. unless someone over torqued them before. the worst thing you might have to do is adjust the holes with a dremel but that's a maybe, I have installed several now and 1 was spot on, 2 needed a slight adjustment and 1 needed more than slight adjustment. You will feel a slight difference in power and it will sound better as well, but only if you take it off your shelf and give it a shot.
Happy Holidays
Did install these on your '97 or '04 ?
