Old 12-22-2010, 12:02 PM   #11
harryrcb
Crazy Austrian
harryrcb's Avatar
Originally Posted by Stroked & Blown
FWIW, I have a set of the chinese headers sitting on the shelf. All the posts about broken header bolts & minimal power gains dissuaded me from installing them.
THat is a real shame, when I installed it on my 97, I had neither of those problems, if you decide to do it, make sure the engine is cold, sitting overnight, the bolts should come right out. unless someone over torqued them before. the worst thing you might have to do is adjust the holes with a dremel but that's a maybe, I have installed several now and 1 was spot on, 2 needed a slight adjustment and 1 needed more than slight adjustment. You will feel a slight difference in power and it will sound better as well, but only if you take it off your shelf and give it a shot.
Happy Holidays
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
