Old 12-22-2010, 11:58 AM   #13
kcpaz
Not quite the same thing.
What you are referring to is removal of the balance shaft, not an intermediate shaft. The makes you point out use a rotating mass to dampen vibrations. The IMS in a M96 Porsche is not there for this purpose, the crank turns one end of the IMS, the other end turns the camshafts; remove it and the engine will not operate..................
I didn't say they were the same, I was using that as an example of eliminating an unnecessary system that over complicates an engine. I understand that the M96 does not use a balance shaft. What I said was the Subaru engines which are also horizontally opposed and also come in 4 and 6 cylinder version do not use an intermediate shaft and have no reliability issues because of it.
And Subaru does not use balance shafts either.
kcpaz is offline   Reply With Quote
