Old 12-22-2010, 10:56 AM   #4
Mark_T
From what I understand, if your AOS is bad then it will be difficult to remove the oil cap due to excessive suction. I don't know if hot/cold makes a difference, but I would venture to guess that if your AOS is bad and you have thick smoke billowing out the pipe, it might not be a good idea to keep it running long enough to warm up. I also don't know what amount of suction, if any, would be considered normal, but perhaps someone else can answer that.
'99 black 986
