Originally Posted by Lobo1186
Adam is correct. Unlike the 2.7 and 3.2 engines that utilize four cats (two of which are incorporated into the headers), the 2.5 variant only uses one set that are located further down stream. Therefore, you could conceivably change headers and still have the vehicle remain OBD II compliant. Whether or not a set of $85.00 headers found on on Ebay is the appropriate choice is another question.
Addendum: Now that I see that your vehicle is a 2.7, that raises two immediate concerns. First, by eliminating the oem header/pre-cat set up, your vehicle will no longer be OBD II compliant. Secondly, it was my experience that "going catless" resulted in a significant loss of low end and mid range torque. This has been commented upon in numerous threads.
