Regarding suspension "harshness", I found that tyre type and pressure are critical to comfort & roadholding - more so than the technical differences between base & S suspension.
Top quality tyres like Michelin Pilot PP2's with relatively soft sidewalls ride far superior on a Boxster compared to cheaper stiffer walled tyres like Khumo or Goodyear.
On the technical side of the S equation, don't rule out the value of the bigger brakes (Brembo monoblocks) and cross drilled rotors, coupled with an extra coolant radiator in the nose plus a bigger water/oil heat exchanger.
These mods alone are worth a lot of kudus & smack of upgraded "sports car" type performance above the base model......
2001 MV Agusta F4.
