Old 12-20-2010, 01:21 PM   #10
jcb986
jcb986's Avatar
Engine overhauls depend on what's done.
option 1- you pull the engine and decide to go thru it and replace only the worn parts...rings, timing chain guides, seals, main and rod bearings, engine colded dipped to remove all sludge, all gaskets, etc. Magna-flux heads, refinish the valve seats and valves, cam bearings, etc. This can be done for around $2000, engine only. The removal and re-installation will cost more. I would say maybe you will get another 30-40K miles on it.
option 2- do everything above and replace the crank, rods, pistons, chains, etc. Add new heads, since I would not trust old rebuilt heads that have several years of driving on them. Remember, they are made from an aluminum alloy and heat will cause them to crack, usually at a water jacket or exhaust valve guide area. Now you are looking at a $10-12k motor.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
