Usually if the engine goes 60-80K miles, you got a good motor. I have seen rebuilt and removed engines for around $4500. Add $1,200 to $1,500 for indy to replace. IMS replaced, I would use Porsches newer bearing and forget the LMS offer. Replace the IMS bearing and RMS seal along with the clutch...I assume you need one and you can save big $$$.
