Originally Posted by Stephan Silverman
I want a used Boxster and am on a limited budget. I would like to spend around $20,000.
I was told to absolutely get the S for the performance and absolutely get a 2003 or later. What do you experienced owners think? Are these important? I do like as much performance I can get from a stock car. But does the S matter that much and why a 2003?
Steve
1) If you are mostly driving to the mall on city streets and at semi-legal speeds on the interstate, or if you're out in the twisties behind an old pickup truck driving 45 mph, the base model is just as fast as an "S." In fact, an old Toyota Corolla is nearly as fast, costs less, and probably is more reliable.
2) If your wife insists on riding with you and then gets after you to slow down all the time, the base model is a better choice ... unless of course you are actively seeking divorce.
3) The dude in the next lane in the Corvette at the stop light is still going to outrace you when the light turns green, no matter which model you buy -- unless you are committed to spending several thousand dollars more to buy a bunch of speed equipment, that will void your warranty and probably make your car blow up.
4) The general public doesn't know the difference between an "S" and a base model. The base model lets you have the prestige of driving a "Porsh" for a much lower cost. Within this community, the base is the Rodney Dangerfield of Porsches.
5) If you never drive an "S," you can't miss what you never had. Ignorance is bliss.
