Old 12-18-2010, 11:43 AM   #3
jcb986
jcb986's Avatar
Did you check the electronic connection plug on the TIP. It plugs in under the car so you can remove the TIP. You may have moisture or water there...use a top quality electrical contact cleaner if necessary. The ECU under the drivers set needs to be checked by a Porcshe dealer. If it's bad the cost is around $1500. Now, if your TIP is bad, look for a used one at a Porsche dismantler. Mike, my fluid was the same color...you should have drained the fluid very well and it should have only taken 6-7 liters of fluid...ONLY that since you cannot drained the converter or fluid from the front oil cooler.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
