Old 12-17-2010, 08:01 AM   #1
yelojkt
As long as you have an M96 motor with a IMS you should keep the bearing in the back of your mind. But it has not been sitting in used oil for 4-8 years now. As long as you keep your oil changed at least once a year you should be good. For total confidence in the bearing it can be replaced each time the clutch is done.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
