I don't know what you're looking to spend, but I have Focal 100v2 components in the dash, I believe they cost $279 for the pair.....They will fit in the stock mounts, but they need a little customizing to get them to fit.....I had Rod @
www.caraudioinnovations.com mount mine, I didn't want to screw them up.....He will give you directions on how to do it yourself if you want to give it a go....Otherwise he will charge $100 for the fit w/speaker wire.....You then remove your old speaks and mounts and return them to him, and he will give you the $100 back.....
I like'm , and it keeps everything stock looking
The MB Quarts I heard will work also, but I am not sure if they will need some customization as well.....also....
The Focals are mids/ tweeters, so they are not meant to pump out anything below 100hz....
Lou
