Originally Posted by harryrcb
Just the standard magic. apperently it doesn't make any difference with or without headers and mufflers,cold air etc, when I originally installed the software I had non of it, but had intended on installing all that and when I did it ran even better with the dyno results to prove it.
When you say this, do you mean that you compared the setup of [stock + softronic] compared to [modded with headers/intake + softronic].. which would make sense of the dyno results... or are you saying you compared [modded with softronic Unflashed] compared to [modded + softronic flashed] and noticed a difference?
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
