Old 12-14-2010, 08:57 PM   #7
seningen
seningen's Avatar
Originally Posted by sb01box
I took the mechanism apart and found cold solder joint between the printed wiring board and the connector. Reflow solder and it's back to normal. Mind you that my unit behaved erratically when the harness/connector was wiggled.
If you encounter similar situation, you may want to open the unit up and see. an hour of labor saved me $$$
here's a photo of the printed wiring board
Where do you find this -- is this inside the door panel?
thanks,
mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is online now   Reply With Quote
