If you're jerking the car (no pun intended) then that means you're not shifting properly.
You need to rev match when downshifting or shift into gear from neutral at speed.
Search on youtube on "double clutching" and "heel and toe".
The only time that you would press both the clutch and brake pedals are when you're doing an emergency stop.
Yeah you're not driving if you have an auto. I learn that when I got this car.
