Old 12-10-2010, 04:39 AM   #2
Flat_Six
well......
All lines and everything has now melted, i took the pipe off the nipple behind the wheel liner and bleed the system so it was empty. I then put at least 4 litres (a gallon) of antifreeze/washer mix into the tank, then tried the washer jets for a while and still nothing comming through
Does anybody have a diagram of how the washer system works? just so that i can try and eliminate the problem.
The washer tank hasnt cracked or split because there isnt a leak, the hose from the tank to the nipple hasnt cracked because it isnt leaking, and it isnt blocked because i bled the system through the hose.
So i dont know where else to look now???
Lee
Flat_Six is offline   Reply With Quote
