Thanks,
This sounds like it may be the case. When I pull the inside handle, there is spring tension, but it is different from the driver's side. The driver side has an additional tension feel when you pull it 1/2". The passenger side doesn't have the additional tension, which leads me to believe the cable is disconnected.
I saw in the Bentley manual (after the fact, of course) the note about the hook you need to connect prior to reassembly. I didn't do this, but I get the impression that this is only if a remove the lock assembly, is that correct?
Bottom line, I still need to get the door open prior to removing the panel. Any suggestions?
