Old 12-08-2010, 02:49 PM   #1
Steve Tinker
Steve Tinker's Avatar
Don't forget to replace the cabin filter and clean out the drain holes front and back.......
To get to the clutch bleed nipple (its a mongrel to get at) you will probably find it easier to remove the aluminium plate mounted under the engine / transmission. If you have to remove that, you may as well change out the gearbox fluid too.
2001 MV Agusta F4.
