Old 12-06-2010, 10:08 AM   #3
BassMD
Originally Posted by eightsandaces
This is from memory, its in the bentley book mine is with the car, first you remove the plastic finish collar surround piece. You need something pointy to work with like a nail set. Then you will see a small dimple on the metal collar now exposed with the trim piece off, if memory is right you press the dimple and its a twist lock.
I removed the rubbery trim piece and what is revealed is a plastic collar around the switch, with a tab at 12 O'Clock. I tried pushing and pulling gently on the tab, and twisting, but nothing budged. Not wanting to break anything, I desisted. Advice?
BassMD is offline   Reply With Quote
