Start the car and let it idle, then try removing the oil fill cap in the trunk. If it is difficult to get off, you have a blown AOS and need to park the car until it is fixed. To do otherwise is to risk blowing your engine............... And, no, a blown AOS will not always trigger a CEL............
this is the advise you should listen to
