Old 12-03-2010, 09:49 AM   #3
extanker
how fast does it get to dead head psi ? it should take a second or 2. leave the fuel psi tester on it for the 1 hr .is it holding psi? have they done flow/volume test ? on some early gm cars an amp draw for the pump can tell you a lot on the pumps condition. if its not holding psi for the spec time its going back to the tank but these pumps are/should be quick enuf to let it start after extended cranking time. dont overlook fuel pump voltage
extanker is offline   Reply With Quote
