I'd put money on your ignition switch. Try wiggling the key and pushing it in and pulling out on it and see if you can duplicate the problem.
When this cheap little plastic part falls apart inside, it makes your boxster downright demon possessed. Wipers starting without warning. AC panel blinking.
The stealership will only replace the whole key mechanism for $$$ but you only need a $18 plastic part that can be purchased from any Audi parts counter if indeed this is the culprit.
