Originally Posted by eightsandaces
All the way back to carburetor engines the air filter housings have had that metal, anteater type intake. If it was good enough for my dad's 396 turbo jet to breathe through, it should be great for a Porsche with the factory cold box set up. I experimented like you then settled for this compromise, I removed the tray cup that partially blocks the intake opening. Then I polished it with a variety of methods which I'm sure is totally subliminal in effect but hey placebos work all the time. Anyhow, it's my take on the intake.
When I had the intake vent out I was thinking of doing something similar to your setup. I was also considering getting another snorkel and reshaping it into a more free flowing air horn but it would require alot of flow modeling and bench testing. I used to do alot of CFD in grad school but for the small gains that would yield, I'll just stick with the stock snorkel.
