Originally Posted by livin_in_a_boxster
Thanks for the response. The battery has been drained several times. There is water in it though and all the connections are clean and tight. But I am guessing it might not be holding a charge like it should and causeing a strain on the system, what should the battery test at voltage wise when the car is off?
I just went through this exact same scenario; to make a long story short, it was the alternator. And replacing it is a relatively simple task that takes about 2 hours if you're not the best mechanic (i.e. me).
Best,
Jon
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
